Posted by Bob M on December 12, 2012 at 07:52:24 from (69.207.86.27):
In Reply to: 53 SH Sediment Bowl posted by Va Gasman on December 12, 2012 at 04:52:04:
There is no separate "seat" in the sediment bulb assembly. Instead the needle seats directly into the native pot metal (zinc) casting. Either the zinc has deteriorated in the seat area (most likely) or the end of the needle is severely worn or has broken off.
Suggest removing the needle and checking the seat area. If it's pitted you might be able to renew by carefully grinding with a suitably shaped burr.
However the best fix is to replace the entire bulb assembly with new.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
