53 SH Sediment Bowl
Posted by Va Gasman on December 12, 2012 at 04:52:04 from (75.192.173.254):
I have a regular SH and Stage ll. The sediment bowl on the regular leaks gas out the carb line when the screw is turned in to stop. The Stage ll never has an issue . As far as i know they are both the original sediment bowls. Is there a repair I can try for this needle valve screw? is the seat brass or a soft surface. I have not removed the bowl assembly at this point.
