Re: 1947 Farmall B no spark
Posted by old on December 12, 2012 at 08:50:37 from (4.244.219.117):
In Reply to: 1947 Farmall B no spark posted by Dave H (MI) on December 12, 2012 at 07:44:09:
As I said the other day move the crank so the points are open. Take one of the 2 small wires off the coil does not matter which one be it distributor side or ignition side and if you get a spark when you hook and unhook that wire you have a short in the distributor be it the insulator or you have one of the wires from the condenser etc shorting out. No test light needed but you do need to be where the sun light is not so bright as to hide the small spark that you should not see
