Re: Super MD carb question
Posted by Janicholson on December 13, 2012 at 07:25:59 from (199.17.6.160):
In Reply to: Re: Super MD carb question posted by Dan MD on December 13, 2012 at 06:47:30:
One condition might be an over rich mix for start operation. On mine, it was necessary to keep it rich to allow it to run, and that ment some choke for about 30 seconds. Then it seemed kinda rich even then. Maybe your carb is rich and fuel is condensing into the intake runners.
The butterflys are adjusted as you have done to get them to seal up. however if the linkage or mechanical stops are out of adjustment, they can be held open. One issue is that the stops must be set to """just""" shut, or, if too tight, the plates will stick shut in cold weather and not allow diesel. Jim
