Re: Super MD carb question
Posted by n9lhm on December 13, 2012 at 08:18:55 from (38.111.252.2):
In Reply to: Super MD carb question posted by Dan MD on December 13, 2012 at 06:44:34:
The valves close when starting to make the engine pull air through the carb. There is nothing to prevent the engine from still pulling air through the carb when on diesel mode, except that the diesel air-only passages are much bigger. That's why there is a valve on the carb to shut the gas off when on diesel. They all rev up on switchover when its cold outside, you will probably notice it's much less in warm weather.
