Posted by Dan MD on December 13, 2012 at 06:44:34 from (199.61.25.253):
This message is a reply to an archived post by DanMD on August 09, 2012 at 09:53:42. The original subject was "Super MD carb question".
Well I have been shutting the gas off and letting the carb run dry and then switch it over and it still revs up. I pulled the manifold off after running on gas and shutting down without going to diesel. I found gas on the walls of the manifold and in the head past the butterfly valves. It was wetter on the front two cylinders. I checked the aircleaner and it has no restriction. I checked the butterfly valves and they are closing fairly good. I put a shop vac on the head side of them and using a smoke stick, I have to have the smoke stick right at the intake for the vac to be able to pull any smoke in at all. My local service manager thought they looked good also.
Any thoughts on how I am getting gas in the diesel intake? I also believe the valves are all set correctly in the head.
If it is the buttefly valves leaking, how do you get them to seal up better? I let them find center and tightened them up already. Dan
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
