Re: SUPER A CRANKSHAFT UPDATE
Posted by Bob R on October 28, 2000 at 14:21:55 from (209.198.80.239):
In Reply to: SUPER A CRANKSHAFT UPDATE posted by BRAD on October 28, 2000 at 12:42:58:
You could drop the oil pan . Take the main and rod caps off, that you can get to . most likely a piston is stuck . You might be able get at the piston if you can turn the crank away .
You could also hit the piston useing a block of wood . Maby shock the piston loose . Be carefull and take your time .
Anyone else help ?
Post A Followup
: Re: Re: SUPER A CRANKSHAFT UPDATE
