300 Utility starting issue
Posted by wlubb on December 15, 2012 at 13:31:11 from (70.194.129.250):
I have a IH 300 Utility and have a issue starting it. It does not start most time with the key, I cleaned all the cable connections, ground connections, etc and still no luck. It will start up fine if I use a screw driver and cross the terminals on the soleniod. Is this a key issue or solenoid issue, I would not think it is a battery or starter issue as it turns over fine and starts when I use the screwdriver. It sounds like the solenoid is trying to engage when I turn the key, but nothing. This is a 6 volt system.
Thanks
