Re: 300 Utility starting issue
Posted by Janicholson on December 15, 2012 at 13:56:33 from (199.17.6.54):
In Reply to: 300 Utility starting issue posted by wlubb on December 15, 2012 at 13:31:11:
If you jump from the battery connected terminal, to the small S terminal and it starts, it is the little wiring, or the key/switch. If you jump from big terminal to big terminal, it is likely that Relay. Jim
