Re: more power for SMTA
Posted by Dale13 on October 29, 2000 at 02:42:54 from (207.1.6.113):
In Reply to: more power for SMTA posted by Travis on October 28, 2000 at 18:36:09:
Look in the archives under[ more power for farmall M] or [souped up super m] these will give you some ideas. things that will give you the most bang for your buck would be a good carb rebuild including some venturi polishing and maybe rejetting, a good 3 or 5 angle valve job[5 angle is they back cut the valves with 2 angles to help flow] and mill the head,adjust your valves a little tighter on the intake i.e. the spec is .17 for both intake and exhaust,I go .12 intake and .15 exhaust.This gives you more lift and also effects duration. If you were to rebuild there is a lot more to do!! Costs, Carb rebuild around $50,head work $300 to 500,Adjustments to valves done by yourself zero . And don't forget a good tuneup,also set the timing and carb on a dyno if possible,cost for that ran me $70. These things and a lot of other rebuild work netted me 72 horses! Good luck.
Home
| Forums
Today's Featured Article -
Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
