Re: SM PTO parts
Posted by mike1972chev on December 17, 2012 at 18:21:34 from (99.31.12.158):
In Reply to: SM PTO parts posted by Dean Olson on December 17, 2012 at 18:08:01:
You are not missing ANYTHING! Where the arm broke off the shaft is a common issue. You could take it apart and repair what you have easily.
I have extra PTO parts,if you need some,but you can repair what you have there easily. (I did mine)You need to tear it down BEFORE re welding it.
