Re: Farmall 400 Dieseling: Doggon It..
Posted by John in Iowa on October 29, 2000 at 07:33:24 from (199.108.164.23):
In Reply to: Farmall 400 Dieseling: Doggon It.. posted by Jon on October 28, 2000 at 19:52:42:
I rebuilded a 400 about 7 years ago and when I did I put in 4 1/8 high dome pistons and had the head rebuilded. I too have the dieseling trouble and have talked a few old HI hands who said that would happen. They knew of no cure. They did say to let it cool down before shutting it off would help. As far as the timing, set it TDC center with the engine off, then see if its 25 deg when running a high idle. If its not, then you may want to rebuild your distributor. Also pull the TA back when shutting it off. With it foreward you can damage the overiding cluth in it. By the way my 400 has a very big attitude. It pulls a 13' disk with no trouble and I have 15.5 tires on the rear.
Post A Followup
: Re: Re: Farmall 400 Dieseling: Doggon It..
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
