Re: IH distributor rotor retainer/spring clip????
Posted by Jim Becker on December 19, 2012 at 13:29:24 from (173.74.120.222):
In Reply to: IH distributor rotor retainer/spring clip???? posted by mike1972chev on December 19, 2012 at 05:29:03:
As long as the rotor is tight enough to be generally pointed towards the electrode for the proper cylinder, looseness will have absolutely no effect on timing. The timing is determined by rotation of the cam, which is not driven by the rotor. The absolute rotation position of the cam will be affected slightly by wear in the valve train and gear reduction of the battery ignition unit. However, any change due to wear of those parts is compensated for each time the timing is set.
By the way, the spring built into the center contact of the rotor keeps it in place as long as the cap is on. The only time a loose rotor can hop off is when the cap is removed.
