Re: IH distributor rotor retainer/spring clip????
Posted by mike1972chev on December 19, 2012 at 14:14:38 from (99.50.224.151):
In Reply to: Re: IH distributor rotor retainer/spring clip???? posted by Jim Becker on December 19, 2012 at 13:29:24:
I would say all that you have said here Jim Is
GENERALLY good,but I have a few issues with it.But
if we wer going to "nit pick" this statement:
#1 You WILL NOT compensate for loose timing
components by resetting timing!(Cam gears,crank
gears,timing chains,distributor drive
gears,distributor cap that has a bad indexing
tab,even oil pump drives(I bet I will get
questions about that one???:)rapid rpm changes up
and down will change timing on an engine with
loose components.
#2 Like I originally stated :It would take ALOT of
the rotor to be out of phase to fire out of
time,UNLESS you couple a slightly loose rotor
with an alternate path for the rotor to be
pointing to an alternate grounding point other
than the correct pole in the cap.Examples:Carbon
tracking inside the cap,cracked cap,1 pole in cap
corroded,will jump to NEXT available ground,like
NEXT cylinder in firing order.)
Those are unlikely scenarios that might happen and
also prove only that a cap is bad and being the
issue. But I have even seen rotors from the
factory that are pretty far out of phase. I have
seen them right when the points are breaking to
let the coil discharge that the rotor is BARELY
favoring the correct cylinder to be firing!!
I know on these old tractors we play with that we
can generally get away with murder because of the
lower RPMs and low horsepower/low compression,ect,
(The distributor MIGHT be turning 800 rpm at best
on average??)On a high RPM engine you couldnt.
Generally,I agree with what you said,but the are
situations where it WILL mess with timing.
