Re: Re: Clutch Adjustment on a Super A
Posted by Tyler (MD) on October 29, 2000 at 12:45:29 from (207.172.145.72):
In Reply to: Re: Clutch Adjustment on a Super A posted by Bob R on October 29, 2000 at 06:23:47:
Bob,
Thanks for the advise. I adjusted the pedal free play to an 1 1/2. It was only an inch. It helped a little. It still takes about 4 seconds after mashing in the clutch in order for it not to grind when putting it in gear. This is at lowest idle. I also greased the 2 zerk fittings on the release bearing.
What do you think? Time for a clutch rebuild?
Appreciate the info.
Tyman
Post A Followup
: Re: Re: Re: Clutch Adjustment on a Super A
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
