Replacing oil seal on Farmall C axel ?
Posted by Paul Shuler on December 21, 2012 at 06:13:34 from (170.29.64.4):
third party image
After the holidays are all over I need to replace the oil seals on my old farmall C axel. I have a couple of questions about it. First can the axel housing be removed and slid off over the axel and job be done that way leaving the axel in place? Or do I need to pull the bolt on the inside and slide the axel out fist. I have an IT manual to look at that shows it in detail but does not give a step by step description of how to do it. Would like to here from you guys that have done it before. Thanks
Paul
