You have to pull the housing, the inner seal is the problem, there is not supposed to be any oil in the housing, the outer seal is just a grease seal. Replace the gaskets while you are at it. I suppose you can slide the housing over the axle but I have never done it that way. I remove the housing and axle as a unit, not saying I won't try it sometime.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
