Re: No valve seals found in IH 404 prior to rebuild.
Posted by pete 23 on December 21, 2012 at 15:48:57 from (74.32.238.2):
In Reply to: No valve seals found in IH 404 prior to rebuild. posted by RandyDowdy on December 21, 2012 at 13:46:41:
If it was mine I would put perfect circle seals or
equivelent on it. A worn rocker arm and shaft
assembly throws a lot more oil over the top of them
valves than it did when it was new. You will see it
smoke at start up if it needs seals but does not
have them. Umbrella was a economy version for
manufactures to get by with. If you look at the
Neuss, (German) engines you will see a good seal on
all valves.
