1944 Farmall H engine rpm's
Posted by Rose Smith on December 21, 2012 at 17:05:20 from (70.199.121.165):
My friend recently acquired a 1944 Farmall H. On the serial number plate, it lists the engine rpm for fast idle as 1815, and says do not overload. All the books we"ve seen list the high end of the rpm range as 1650 for this model. The serial number starts with the prefix FBH and ends with the suffix XC. The manifold has a lever-controlled butterfly for heat control, so we figure it"s the low-compression engine that can run on kerosene. Any information on the high rpm listing or what the serial number suffix indicates?
