Re: 1944 Farmall H engine rpm's
Posted by athol carr on December 21, 2012 at 17:39:56 from (115.188.3.223):
In Reply to: 1944 Farmall H engine rpm's posted by Rose Smith on December 21, 2012 at 17:05:20:
The rated rpm is 1650 which is what the governor should control the engine at under full load. The 1815 rpm is the no-load maximum speed.
