Re: A few questions before I buy my first Super A
Posted by gene bender on December 22, 2012 at 02:13:36 from (67.55.227.74):
In Reply to: A few questions before I buy my first Super A posted by DirtyJ on December 17, 2012 at 13:59:59:
Bes way to check steering is jack the front up till the wheels are free then starting at the tie rods work back to the steering arm off the housing looking for play probably need to rebuild the steering housing with new seals key on out-put shaft and maybe the bearings. Cost for all the seals and bearings will cost around 50 bucks. Just remember a little play here and there will soon add up to a bunch. When jacked up if you can wobble the out-out arm on the steering sector it needs to be rebuilt inside. The key on the out-put shaft can also be worn as it lets the gear have play.
