Re: Keeping 6 volt+magneto system-need schematic
Posted by Bob M - w/diagram on October 30, 2000 at 05:27:52 from (192.232.120.194):
In Reply to: Keeping 6 volt+magneto system-need schematic posted by Jim Hines on October 29, 2000 at 12:09:37:
Jim - Your '48 M should be wired up same as in the diagram above. (Thanks to Farmer Bob for scanning and sharing!) The backward-reading ammeter is consistant with the battery being hooked up negative ground. If you swap the battery cables, the ammeter will again read correctly. But if you swap the ground, be sure to repolarize the generator also: Momentarily connect the BAT and GEN terminals on the cutout with a jumper wire before starting the engine. If the charging system is properly connected and working properly, you should get the following test results: 1 - With engine off and lights on "B" (bright) ammeter should read somewhere around -15 amps. 2 - With engine idling the lights off, ammeter should read 0. 3 - With engine up to full RPM and light switch set on "H". Ammeter should read somewhere around +15 amps. If you have an accurate voltmeter, voltage across the battery terminals should be between 7.0 and 7.5. 4 - Again with engine at full RPM, but light switch on "L", ammeter should read about +5 amps. Post back your findings and we'll try to help... A couple other comments: The starter is polarity insensitive - it'll turn the right way grounded no matter which way it's grounded. If this tractor is a working (not a show) tractor and you want it to start reliably in MN winters, think about converting to 12 volts (either generator or alternator). You'll find starting will be MUCH more reliable in extreme cold with 12 volts. ...Bob M
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
