584 auxiliary valve
Posted by warrenwoodrow on December 25, 2012 at 13:44:35 from (108.131.127.113):
I do not use the rear hydraulics and valve body seems to be leaking. I capped two ports going to rear hydraulics . Can I cap the inlet as well and just eliminate the the leak without cvausing any harm to system. Also, if there is a hydraulic leak anywhere in a system does it stand to reason that air may also get into system at that point. Obviously I know verey little about hydraulics.
