Re: 584 auxiliary valve
Posted by jimb2 on December 25, 2012 at 17:30:36 from (174.114.182.155):
In Reply to: 584 auxiliary valve posted by warrenwoodrow on December 25, 2012 at 13:44:35:
Hi Warren, it should be possible to remove the remote valve and bolt the end cover plate to the hydraulic housing. The only problem is the return line (L shaped line) that comes out of the top of the cover plate that goes to the draft control probably will no longer fit. The steel return line can be replaced with a flexible hydraulic hose. If tractor has a front end loader the return line may have been replaced with loader connections.
JimB
