janicholson...preload bearing torque??
Posted by glennster on December 27, 2012 at 13:37:57 from (75.57.134.154):
hey jim, need yer opinion. working on my older prime-mover skid steer. rt front axle bearings. am replacing both bearings, races and seal. has 2 ntn 4t-33895 tapered roller bearings. bearings are 2 1/8 inch wide inner id by 1 1/4. they ride on a 2 1/8 inch axle. has a drive sprocket, thrust washer and castle nut on the inner to hold it all together. no torque specs in the manual for this. any idea what to set the castle nut at? the drive chains and bearings are lubed with 30 wt oil from the chain case. thanks, glenn
