Re: janicholson...preload bearing torque??
Posted by Janicholson on December 27, 2012 at 14:46:50 from (74.60.94.18):
In Reply to: janicholson...preload bearing torque?? posted by glennster on December 27, 2012 at 13:37:57:
In that size range the bearing should be tightened carefully while tapping on the hub with a brass hammer to settle all races against the shoulders. they should be tight enough to feel strong resistance to turning by hand, and rolled several turns. Then back off the nut and tighten them till a spring scale will turn the hub at the sprocket at about 10 oz of force pulling tangentially to the sprocket tooth. Again rotate and tap on it to assure seating, and test the rotational force again. Jim
