Well all but the reading at the coil is correct but the one at the coil maybe off but it may also be correct depending on your meter. A way to see is do this. Run a hot wire from the battery in this case + side to the coil and check voltage at the coil that way. If when you do that and if you get say 12 something volts try to start it that way and see if it starts better. If it does then you have some sort of problem from the coil back to the battery in the ignition wiring. Be it a bad switch or a wire going bad which does happen or other such component in the wiring going bad. By the way that reading you got at the coil tells me the points are open. If the reading was way low as in 1-3 volts that would tell me the points where closed
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
