Posted by Zachary Hoyt on December 29, 2012 at 09:11:04 from (173.84.189.49):
I have been trying to figure out why my 300 is so hard to start. It was fine till about a month ago and abruptly become very hard starting. Once it is running it does okay. I did some electrical investigation today and found a funny thing, unless it is normal and I was just not aware of it. The battery read 12.63 volts with everything turned off. When I turned the ignition on the voltage dropped to 12.29 in about 15 seconds. When I went around to the coil and checked the terminal where the hot wire comes in I had 11.62. When I went back to the battery it read 12.28. I shut the ignition off and came inside here to think about it. If the voltage is dropping below 12 with just the ignition on I assume it is dropping a lot more when I engage the starter. Is it supposed to be like that or could I have a faulty switch or some other problem? Should I open the dash and check the voltage on each side of the switch? The tractor has a 12V conversion with 3 wire alt, wired according to the Bob M wiring diagram. The coil is a new 12V coil bought a couple of months ago, at which time I removed the ballast resistor which had been in the line. The switch was a cheap one from NAPA and sometimes it will not shut off unless I pull it on and then off again. Any advice will be much appreciated. Zach
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one
... [Read Article]
Latest Ad:
[More Ads]
