ALL carbs ice up and it is part of how they work. If the did not your engine would not run it is due to the atomizing of the fuel that in turn cause the manifold area to get cold and it is just normal operation of a carb and you old cars and trucks do the same thing. If it bugs you don't look at it. Yes some time for a bit the engine will not run as well but it should clear up once the engine warms up more. Also opening up the main jet a tad bit helps. So as I said it is normal and nothing to worry about
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
