Re: drawbar roller
Posted by D Slater on December 30, 2012 at 06:26:02 from (184.15.46.232):
In Reply to: drawbar roller posted by johndeeregreg on December 29, 2012 at 18:57:37:
IH considered the swinging drawbar a attachment.
As time progressed IH changed the drawbar supports,front and rear, drawbars and the piviot pin. Without doing any checking I remember the drawbar rollars showing up about the time M production ended.
When IH started to use the bigger in the center roller, think it was to help with wear on the U shaped drawbar and the support above the drawbar.
When the U shaped drawbar was set at different heights the swinging drawbar did not always intersect at a square angle. That would cause the U drawbar and its upper support to wear more on one edge or end. Roller with the high center was supposed to help.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
