Re: drawbar roller
Posted by Janicholson on December 30, 2012 at 08:30:27 from (74.60.94.18):
In Reply to: Re: drawbar roller posted by D Slater on December 30, 2012 at 06:26:02:
I have an H with the barrel shaped roller and I believe it was factory. It came off the truck that way, but I was 4 years old and it could have been a dealer item. Other neighbor's SM tractor had the roller as well. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
