Re: won't start
Posted by rustred on December 30, 2012 at 08:09:40 from (70.28.245.91):
In Reply to: won't start posted by RICK IN VERMONT on December 30, 2012 at 07:54:11:
first thing is ... no such thing as putting valve guides in and nothing else. if thats true what you say then there's a problem right there.valves and seats HAVE TO be ground after guide installation. also are the valves set?
rings and brgs and nothing else? did the cyl's get deglazed? what about ring groove? was it removed? also HAVE TO check compression when in dought. no gas to carb means to check from the tank to carb for line plugs.
this is a few ideas with the little info.
