won't start
Posted by RICK IN VERMONT on December 30, 2012 at 07:54:11 from (71.161.192.143):
1954 SC - rebuilt the engine. It was running when I parked it. I had the head checked at local engine machine shop, all o.k. they put new guides in, nothing else. I installed new rings & bearings, nothing else, now it won't start. Not getting gas at the carb. when turning over there is a "tink-tink" noise coming from exhaust. Timing is perfect. Haven't tested compression but it appears to be o.k. Any thoughts?
