Re: won't start
Posted by David G on December 30, 2012 at 08:09:59 from (205.215.206.18):
In Reply to: won't start posted by RICK IN VERMONT on December 30, 2012 at 07:54:11:
Gotta have gas at the carb before anything will run. On the tink, tink issue I would double check the valve clearances.
