Re: won't start
Posted by El Toro on December 31, 2012 at 09:29:04 from (108.3.143.30):
In Reply to: won't start posted by RICK IN VERMONT on December 30, 2012 at 07:54:11:
Do a compression test and post the readings. Set your valves at .017" cold. Nothing else means you should've installed a new sleeve kit
that included new pistons and rings. That ting you hear is probably a piston ring hitting the ridge in your old sleeves. Hal
