Farmall Tractors Discussion Board
Re: IH 350 Diesel troubleshooting, manuels,parts
Posted by Harold H on January 14, 1999 at 18:04:51:
In Reply to: IH 350 Diesel troubleshooting, manuels,parts posted by keith on January 14, 1999 at 17:34:21:
Keith,
Parts for the Continental engine are hard to find but I think you can eventually find anything but a crankshaft if you look hard enough. You may have injector problems on your engine. You can replace your single front wheel with the tricycle front end from a Farmall H, Super H, 300, 350 or 460. The 460 tricycle will have disc wheels and will not look original, but it will fit. Be sure and note where the stop bolt is and put it in the same hole when mounting the tricycle front. You can purchase new aftermarket wide front axles or might find a used one in salvage yards. In the South there were very few wide front axles in this era. Most Farmalls had single front wheels or dual tricycle front wheels. It was in the 806 era (mid 60's) before wide front axles begain to equal and then pass the tricycle front wheels in sales in the Mississippi Delta.
Harold H
Post a Followup
: Re: Re: IH 350 Diesel troubleshooting, manuels,parts
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
