Re: Frustration
Posted by mkirsch on January 01, 2013 at 10:48:18 from (67.253.161.186):
In Reply to: Frustration posted by Zachary Hoyt on December 31, 2012 at 17:57:44:
Which thing did you do? Hand over the intake, or squirt gas?
Hand over the intake is just a one-time test, like a compression check. Just to see if you've got good suction. Use the choke for starting.
Squirting gas tells me that the tractor simply isn't getting enough fuel. You need a good rich shot of air/fuel mix at startup.
Any idea what your idle screw is set at? I can never remember whether in or out makes for more fuel.
