Re: BATTERY CUTOFF LAST POST
Posted by old on January 02, 2013 at 09:40:11 from (209.86.226.11):
In Reply to: BATTERY CUTOFF LAST POST posted by Bud W on January 02, 2013 at 09:04:25:
In the long run and yes I know a pain but removing the cable off the battery is the best way. Doing it at the starter can cause a problem with the stud working loose and then causing internal problems with the starter plus that stud being brass an soft is likely to wear and then in then cause problems
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
