BATTERY CUTOFF LAST POST
Posted by Bud W on January 02, 2013 at 09:04:25 from (70.242.114.188):
Thanks for the ideas. I was trying to come up with an easy way to install cutoffs outside the battery box and since my tractors are grounded inside the box the only way is to add the cutoff on the hot cable. I now think the best way is just to disconnect the cable at the starter.Thanks again.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
