Re: BATTERY CUTOFF LAST POST
Posted by Rich'sToys on January 03, 2013 at 06:07:15 from (74.44.57.128):
In Reply to: BATTERY CUTOFF LAST POST posted by Bud W on January 02, 2013 at 09:04:25:
If you unbolt the end at the starter, you have to be very careful about protecting the end of that cable. If it accidentally comes in contact with the frame, you will have all kinds of fireworks in a very big hurry!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
