Re: 300 TA or clutch problem, I think
Posted by Zachary Hoyt on January 04, 2013 at 12:56:55 from (74.47.58.105):
In Reply to: Re: 300 TA or clutch problem, I think posted by mkirsch on January 04, 2013 at 12:38:31:
Thank you very much for the help, it is not up and running. I
was able to push the tractor into the shed with the other tractor,
so it is out of the snow. I just went out and tried it again and I
was not able to turn the TA in either direction with the clutch
pedal back. With the pedal blocked I could turn the TA one way,
but the TA clutch disk did not turn. It was stiff to turn by hand
with the TA lever forward and easy to turn with the TA lever
back. I can't seem to get clear in my own mind about what the
TA clutch disk is connected to, I seem to recall from when I was
working on the tractor that when I would turn the TA by hand the
TA clutch disk turned along with the rest of it.
Zach
