Re: 300 TA or clutch problem, I think
Posted by mkirsch on January 04, 2013 at 12:38:31 from (64.80.110.74):
In Reply to: 300 TA or clutch problem, I think posted by Zachary Hoyt on January 04, 2013 at 08:38:42:
Ramp and rollers problem would not cause the engine to stall when you let out the clutch.
Being stuck in two gears would.
I'm not really sure if your troubleshooting of the TA is telling you anything useful. The planetary should rotate in one direction and not the other with the tractor in neutral and your foot off the clutch pedal.
You said "all was normal" does that mean you're back up and running?
