Re: fouled plugs in IH Cub
Posted by Bama Binder on November 01, 2000 at 05:59:29 from (206.5.110.15):
In Reply to: fouled plugs in IH Cub posted by JOHN MONTGOMERY on November 01, 2000 at 04:55:29:
Well...it sounds like you have checked about everything....the Champ D21s are probably about as hot as you should go. Cubs are notorious for fuel dripping out the carb. In most cases, this probably would cause the fuel rich condition you describe.
The usual culprits are 1. float level set too high (manual has instructions on adjusting) 2. float interfering with carb body. 3. bad gasket between the 2 carb halves. 4. float full of fuel (pinhole leak).
Are your plug wires resistance type or solid core? Solid core is probably better for older ignition systems. I would also suspect a weak spark except you have changed all that. Anyway...good luck....BB
Post A Followup
: Re: Re: fouled plugs in IH Cub
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
