300U trans oil?
Posted by Bkpigs on January 05, 2013 at 13:37:37 from (24.182.229.14):
Workin on my Dad's 300U and got wondering. Since the entire transmission is filled with one port, and assuming that it reaches the PTO drive gear in the front by oil ports along side the PTO shaft, where is the weep hole for the TA clutch? Looking at the shop manual diagram of the transmission, it looks like the plate below the TA clutch holds the fluid in the lower cavity. Is there a weep hole to allow oil out if one of the oil seals fails? Appreciate it!
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
