Re: 300U trans oil?
Posted by D Slater on January 05, 2013 at 16:49:10 from (184.15.46.232):
In Reply to: 300U trans oil? posted by Bkpigs on January 05, 2013 at 13:37:37:
Two holes on the bottom of the center housing. One on each side of where the pto shaft passes through the housing. Start looking toward the rear of the tractor from the bathtub shaped cover under the pto drive gear. Maybe around 1/2 inch diameter or a little bigger.
Pays to see if the holes are open at some auctions or other. Once in a while someone has the bright idea to plug the holes just before selling to not show a leak.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
