Posted by da.bees on January 05, 2013 at 19:27:20 from (72.181.183.240):
Not sure wherether 154 questions belong here or garden tractors but here go's.
Is there an electric water pump that can be installed in lower hose. Probably should ask if it is needed/reccomended or does any good. The radiator is clean and I havn't used the tractor in hot weather under a load so I don't know if it heats up or not. Looked to be a new head on it when I got the tractor so I suspected engine may have heated in the past.
All facing is worn off of clutch. What kind of material can be used to reface the clutch? Was the clutch pedal origionaly adjusted so that after clutch stopped turning the wheel brake is applied via the clutch pedal. I figure clutch problems could be common as a result of operators using clutch to stop tractor.
If there is a better place to get info on the 154,please advise me.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
