Re: I H 154 Lowboy
Posted by Fritz Maurer on January 05, 2013 at 19:56:50 from (216.137.138.146):
In Reply to: I H 154 Lowboy posted by da.bees on January 05, 2013 at 19:27:20:
All the clutch parts are still available so it wouldn't make much sense to try to get it relined unless you could get it done cheap. The splines are probably shot anyway, along with the input shaft. It had a clutch brake, but wasn't effective enough to stop the tractor, or cause recurring clutch failures. It's an old tractor; it needs a clutch kit. No big deal. If it has a new head, the old one probably suffered frost damage. If the exterior of the cooling system is as clean as you say, with a good fan belt, and it's full of water, it will never overheat.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
