Re: Farmall M Upper bolster
Posted by Eddie Ward on January 05, 2013 at 21:34:06 from (70.61.112.254):
In Reply to: Re: Farmall M Upper bolster posted by CNKS on January 05, 2013 at 18:38:18:
Yes, thats the other thing I would have to check first is the rules. As far as selling it. I could easly unbolt the light front and put the other back on it plus it has already been modified beyond farm use anyway. Thanks for the input. Eddie
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
