Re: Farmall M Upper bolster
Posted by CNKS on January 05, 2013 at 18:38:18 from (216.144.104.128):
In Reply to: Re: Farmall M Upper bolster posted by Eddie Ward on January 05, 2013 at 16:18:40:
Your tractor, but if you sell it sometime it will be good for nothing but pulling. The bolster will be too light to hold the front end down for general farm use. I know nothing about pulling, but if you are in the stock class it would seem to be illegal.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
