Re: what is the best/easiest way to get this 140 unstuck?
Posted by old on January 06, 2013 at 09:02:18 from (209.86.226.34):
In Reply to: what is the best/easiest way to get this 140 unstuck? posted by PretendFarmer on January 06, 2013 at 05:51:39:
Most of the tractors I deal with are stuck like that one. I use ATF. Fill the cylinders with ATF and put the plugs back in and let it sit a week. After a week set a 12 volt battery in and use short fast taps on the starter. Watch the crank pulley. If it moves any then pull the plugs out and keep trying. If it spins over after a bit you got it but beware the ATF will shoot out of the plug holes and make a mess but hey out of 20 plus only 2 or 3 did not free up for me and I used them on the place now
